Group: DynoMotion Message: 2857 From: himykabibble Date: 1/1/2012
Subject: KMotion_dotNet Error Handlind
Brad,
What is the correct way to handle unexpected disconnects and re-connects? My C# app initializes the board, defines I/Os, axes, etc. But if not board is present, this results in a large number of error dialogs. Seems to me what's needed is an Event that is called on connect or disconnect, so the app can handle transitions gracefully. Is there a simple way to deal with this that I'm not seeing?
Ray L.
Group: DynoMotion Message: 2862 From: Brad Murry Date: 1/1/2012
Subject: Re: KMotion_dotNet Error Handlind
Hello Ray,
   There was much discussion on this matter and it was decided in the end for the calling application to handle connect/disconnect/reconnect situations.
The primary reasoning behind this is that connectivity may be more critical in some applications than others and each may need to handle these scenarios in their own way.
There are recommended mechanisms to cleanly determine whether a connection exists, and the KM_Controller.Connected property implements them in very much the same way as KMotionCNC.
It is probably best to have a background thread to check this property(no less than 100ms between polling for most applications) and on this thread you can route connect/disconnect/re-connect logic appropriately.
-Brad Murry
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble
Sent: Sunday, January 01, 2012 8:18 PM
Subject: [DynoMotion] KMotion_dotNet Error Handlind
Brad,
Ray L.
Group: DynoMotion Message: 2864 From: himykabibble Date: 1/1/2012
Brad,
OK, I can do that easily, since I already have a 100mSec timer to sync up display objects. Thanks. So I also need to wrap each access with a if (Connected) {}, to get rid of the excess error dialogs? Still seems to me it would be useful for the underlying code to keep track, and only issue the error dialog once for each disconnect, no? It seems inconsistent to require the app to track the connected state, but then have the library throwing error dialogs.
Ray L.
> Hello Ray,
> situations.
> in their own way.
> -Brad Murry
> Brad,
> I'm not seeing?
> Regards,
> Ray L.
Group: DynoMotion Message: 2866 From: Brad Murry Date: 1/2/2012
Hello Ray,
I agree with you and that is why there was a lot of discussion about it.  In the end I think it boils down to minimizing USB traffic.
If an application is polling for display/state update and the dll is also polling  for connection then we are risking clogging the USB channel, especially if there are a lot of motion segments being pushed to the controller.
Callbacks as I described earlier to eliminate or supplement  the pop-ups would be nice and Tom has received the request before.
-Brad Murry
Sent: Sunday, January 01, 2012 11:33 PM
Subject: [DynoMotion] Re: KMotion_dotNet Error Handlind
Brad,
Ray L.
> Hello Ray,
> situations.
> in their own way.
> -Brad Murry
> Brad,
> I'm not seeing?
> Regards,
> Ray L.
Group: DynoMotion Message: 2868 From: himykabibble Date: 1/2/2012
So show much can I get away with.... I have a number of GUI elements - DROs, indicator LEDs, etc. that need to be kept updated, and their states can change due to user interaction (via the GUI, dedicated control panel switches, or the pendant) or through G-code operations. The only reasonable way I could see to do this is with timer interrupts that check the current state, and update the GUI as needed. I'm currently doing this every 100mSec. Is this going to be a problem?
Ray L.
> Hello Ray,
> controller.
> -Brad Murry
> Brad,
> error dialogs.
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ,
> Brad Murry <bradodarb@> wrote:
> > Hello Ray,
> > situations.
> critical
> scenarios
> > in their own way.
> > -Brad Murry
> > From: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> [mailto:DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ]
> On
> > To: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > Brad,
> My
> what's
> that
> > I'm not seeing?
> > Regards,
> > Ray L.
Group: DynoMotion Message: 2869 From: himykabibble Date: 1/2/2012
Another problem I'm having - I sometimes open KMotion while my app is open, so I can monitor the board state. But, frequently, when I exit my app, KMotion crashes, after complaining it lost communication with the server. Is there a way around this?
Ray L.
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@> wrote:
> > Hello Ray,
> > controller.
> > -Brad Murry
> > Brad,
> > error dialogs.
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > situations.
> > critical
> > scenarios
> > > in their own way.
> > > -Brad Murry
> > On
> > > Brad,
> > My
> > what's
> > that
> > > I'm not seeing?
> > > Regards,
> > > Ray L.
Group: DynoMotion Message: 2870 From: brad murry Date: 1/2/2012
Nope, I'm using the same interval on a separate thread with no issues.
Try using the KM_Controller.MainStatus structure and supporting methods if you can.  You can call one update every 100ms and then you have all io and axis states.
-Brad Murry
Sent: 1/2/2012 9:47 AM
Ray L.
> Hello Ray,
> controller.
> -Brad Murry
> Brad,
> error dialogs.
> Regards,
> Ray L.
> > Hello Ray,
> > situations.
> critical
> scenarios
> > in their own way.
> > -Brad Murry
> On
> > Brad,
> My
> what's
> that
> > I'm not seeing?
> > Regards,
> > Ray L.
Group: DynoMotion Message: 2871 From: himykabibble Date: 1/2/2012
Brad,
I was just looking at that, and will be switching over to it shortly.... I now have G-code working, including FeedHold, most of the on-screen controls are updating correctly in more-or-less real-time, even when I force changes through KMotion or directly in the DSP.
I sure wish there was an up-to-date list of console messages, parameters and other things. I keep coming across things in the existing code that are not in the Help, like I just found GetStopState, which is needed for doing FeedHold properly. And there are more than a few parameters I don't understand - e.g. - Interpreter "BreakAngle"? Wuzzat? Some things you can kinda figure out by staring at source code, others are just a mystery.
Ray L.
> -Brad Murry
> From: himykabibble
> Regards,
> Ray L.
> > Hello Ray,
> > controller.
> > -Brad Murry
> > Brad,
> > error dialogs.
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > situations.
> > critical
> > scenarios
> > > in their own way.
> > > -Brad Murry
> > On
> > > Brad,
> > My
> > what's
> > that
> > > I'm not seeing?
> > > Regards,
> > > Ray L.
Group: DynoMotion Message: 2872 From: brad murry Date: 1/2/2012
Its pretty cool that with a bit o .net skills a pretty fully functioned cnc app. I here you on the updated script list. Hopefully Tom will find time or at least throw some notes in a text doc so someone else can make the docs. I think the pc6.h or whatever file handles the dsp interop has a list of commands, if not documentation regarding them.
-Brad Murry
Sent: 1/2/2012 11:17 AM
Brad,
Ray L.
> -Brad Murry
> From: himykabibble
> Regards,
> Ray L.
> > Hello Ray,
> > controller.
> > -Brad Murry
> > Brad,
> > error dialogs.
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > situations.
> > critical
> > scenarios
> > > in their own way.
> > > -Brad Murry
> > On
> > > Brad,
> > My
> > what's
> > that
> > > I'm not seeing?
> > > Regards,
> > > Ray L.
Group: DynoMotion Message: 2873 From: himykabibble Date: 1/2/2012
Brad,
Ah! pc2.c - I had not stumbled across that one. That will be a big help.
Yes, is it amazing a complete dope with a computer can so easily get a CNC controller app going. I'm really looking forward to getting it really finished off, though that will take some time, to build all the configuration dialogs, tool table editing, etc., etc. But with a relatively few hours of work, I'm already close to having something I could actually use for simple jobs. That is pretty amazing. a LOT of the credit goes to you. I never could've done it without your work on the .NET wrappers - I would've had a VERY hard time getting motivated to even try this in C++ and MFC.
Ray L.
> -Brad Murry
> From: himykabibble
> Brad,
> Regards,
> Ray L.
> > -Brad Murry
> > From: himykabibble
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > controller.
> > > -Brad Murry
> > > Brad,
> > > error dialogs.
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> > > > situations.
> > > critical
> > > scenarios
> > > > in their own way.
> > > > -Brad Murry
> > > On
> > > > Brad,
> > > My
> > > what's
> > > that
> > > > I'm not seeing?
> > > > Regards,
> > > > Ray L.
Group: DynoMotion Message: 2877 From: Tom Kerekes Date: 1/2/2012
Hi Ray,
We hadn't realized the Console Screen Help hadn't been updated.  Here are some newer help files:
The Trajectory Planner related settings are described in the KMotionCNC help.  See:
Group: DynoMotion Message: 2887 From: Tom Kerekes Date: 1/2/2012
Hi Ray,
Not sure why this is happening.  The only thing I can think of is when talking to the libraries an app often "Locks" the Server.  This can happen by doing a WaitToken/ReleaseToken or internally with a WriteLineReadLine for example.  Could you be in the middle of communicating with the Server when your app terminates?
Group: DynoMotion Message: 2890 From: himykabibble Date: 1/2/2012
It is possible it's in one of the 100mSec updates. I'll try disabling the timer before closing the app, and see if it goes away. That's a reasonable explanation, and would explain why it doesn't happen all the time. Thanks!
Ray L.
> Hi Ray,
> Sent: Monday, January 2, 2012 8:48 AM
> Regards,
> Ray L.
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > controller.
> > > -Brad Murry
> > > Brad,
> > > error dialogs.
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> > > > situations.
> > > critical
> > > scenarios
> > > > in their own way.
> > > > -Brad Murry
> > > On
> > > > Brad,
> > > My
> > > what's
> > > that
> > > > I'm not seeing?
> > > > Regards,
> > > > Ray L.
Group: DynoMotion Message: 2893 From: Brad Murry Date: 1/2/2012
A good place to do that would be by overriding your form’s OnClosing::
        protected override void OnClosing(CancelEventArgs e)
            base.OnClosing(e);
And maybe even double checking in  OnClosed()
I use the WPF equivalents of these in MM and it seems to work OK.
-Brad
Sent: Monday, January 02, 2012 6:20 PM
Ray L.
> Hi Ray,
> Regards,
> Ray L.
> > Regards,
> > Ray L.
> > > Hello Ray,
> > > controller.
> > > -Brad Murry
> > > Brad,
> > > error dialogs.
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> > > > situations.
> > > critical
> > > scenarios
> > > > in their own way.
> > > > -Brad Murry
> > > On
> > > > Brad,
> > > My
> > > what's
> > > that
> > > > I'm not seeing?
> > > > Regards,
> > > > Ray L.
Group: DynoMotion Message: 2894 From: himykabibble Date: 1/2/2012
I think that may have fixed it. We'll see how it goes. Thanks!
Ray L.
> A good place to do that would be by overriding your form's OnClosing::
> base.OnClosing(e);
> -Brad
> Tom,
> Regards,
> Ray L.
> Tom Kerekes <tk@> wrote:
> > Hi Ray,
> > Â
> > Â
> > Â
> > Regards,
> > Ray L.
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> it. In
> also
> > > > controller.
> pop-ups
> > > > -Brad Murry
> On
> > > > Brad,
> up
> me it
> the
> require
> throwing
> > > > error dialogs.
> > > > Regards,
> > > > Ray L.
> <mailto:DynoMotion%40yahoogroups.com> <mailto:DynoMotion%40yahoogroups.com>
> > > > > Hello Ray,
> end
> > > > > situations.
> > > > critical
> > > > scenarios
> > > > > in their own way.
> connection
> very
> property(no
> thread
> > > > > -Brad Murry
> > > > On
> > > > > Brad,
> re-connects?
> > > > My
> board is
> me
> > > > what's
> app can
> this
> > > > that
> > > > > I'm not seeing?
> > > > > Regards,
> > > > > Ray L.
Group: DynoMotion Message: 2895 From: himykabibble Date: 1/2/2012
Brad,
BTW - Is there anything special I should do with the Controller object before closing, or will it automatically clean up after itself?
Ray L.
> base.OnClosing(e);
> -Brad
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Regards,
> > Ray L.
> > > Regards,
> > > Ray L.
> > > > Hello Ray,
> it. In
> also
> > > > controller.
> pop-ups
> > > > -Brad Murry
> On
> > > > Brad,
> up
> me it
> the
> require
> throwing
> > > > error dialogs.
> > > > Regards,
> > > > Ray L.
> > > > > Hello Ray,
> end
> > > > > situations.
> > > > critical
> > > > scenarios
> > > > > in their own way.
> connection
> very
> property(no
> thread
> > > > > -Brad Murry
> > > > On
> > > > > Brad,
> re-connects?
> > > > My
> board is
> me
> > > > what's
> app can
> this
> > > > that
> > > > > I'm not seeing?
> > > > > Regards,
> > > > > Ray L.
Group: DynoMotion Message: 2900 From: bradodarb Date: 1/2/2012
Hello Ray,
I would call
KM_Controller.Dispose();
-Brad Murry
> Brad,
> Regards,
> Ray L.
> > base.OnClosing(e);
> > -Brad
> > Tom,
> > Regards,
> > Ray L.
> > > Hi Ray,
> > > Â
> > > Â
> > > Â
> > > Regards,
> > > Ray L.
> > > > Regards,
> > > > Ray L.
> > > > > Hello Ray,
> > it. In
> > also
> > > > > controller.
> > pop-ups
> > > > > -Brad Murry
> > On
> > > > > Brad,
> > up
> > me it
> > the
> > require
> > throwing
> > > > > error dialogs.
> > > > > Regards,
> > > > > Ray L.
> > > > > > Hello Ray,
> > end
> > > > > > situations.
> > > > > critical
> > > > > scenarios
> > > > > > in their own way.
> > connection
> > very
> > property(no
> > thread
> > > > > > -Brad Murry
> > > > > On
> > > > > > Brad,
> > re-connects?
> > > > > My
> > board is
> > me
> > > > > what's
> > app can
> > this
> > > > > that
> > > > > > I'm not seeing?
> > > > > > Regards,
> > > > > > Ray L.
